Turning prop on Bravo 1 right and left with hand backlash sond
I just want to know if it is normal that i seem to have a litle free play when i turn the prop right and left ? I can hear a sond (click) when i turn it right and left like a free play in the gear or in a coupler???? The drive is a Bravo 1.
Does it is normal or not????
Thanks in advence for the info!!!
Charter Member #601
Could be the upper vertical shaft moving up and down, as you change direction. Find another boat at the launch and try that one. I bet you will find it the same as yours. Rocking the prop back and forth isnt a good way to tell what is going on inside.
Hope that helps.
Dick
Hope that helps.
Dick
