neo oil results w 1000 hp in front of Bravo
#41
The cooler and pump deal is a great idea and only cost about what a set of lower gears and bearings does so well worth it, the idea was implemented by Drew marine and improved upon by dick tryce/mr gadgets, I just followed their advice but never the less does help. I used to change lower gears in less than 15 hours running hard and am seeing 50 pus hours now so I am pretty happy overall, thanks, Smitty
#42
#43
First, Talk to Mr Gadgets for fittings that go into the drive.
The rest is available at Summit at your door tomorrow:
-Tilton gear oil pump or a pump like Smitty has pictures of
-AN lines inside
-Polypropylene with stainless braided lines and stainless fittings outside
-Remote oil filter to bolt to the transom inside (Summit)
-Switch on dash
Here is a picture of my setup (the lines dont go into the transom plate, they just happened to be setting there, they actually go to the oil cooler)
I can easily get to my filters by putting one arm down by the exhaust with a filter wrench, then screw a new one on.
#44
Like Artic (Smitty), I have tried all of the other gear oils and nothing compares to the NEO oil. I have a heavier boat, and 900 ft lbs. I run 25 hrs per season. When I drain it in the fall, it is literally the same color as it went in. And no fuzz on the magnets. We use it in all of our Porsche race cars. That is a real test there. We used it when we won the 24 hrs at Daytona in our Cayman. Car only stops for fuel and tires.
#45
With all due respect Arneson never crossed your mind? Been around way longer than 5 yrs
#46
I know this was asked towards art but I also pondered an arneson drive conversion for the last 2 seasons, this is what I've concluded.
in a single application in the 23-28 foot range there aren't many boats to base the success off of. Rik seems like an insanely knowledgeable guy but i disagree that a surface drive works in every application. In art's application as well as mine our hull design I personally don't feel the arneson would work quite as well as a stern drive. Prop walking/hopping and lack of bow lift would make the boat run flat or perhaps even bow down. You could easily spend thousands in prop tweaking and never quite get the results you're shooting for. Again I'm not knocking the arneson in any way shape or form. A 100 foot rooster tail would be awesome.
Articfriends also has tried an extension box and a shorty both resulting in worse handling and slower speeds.
I think the arneson works best where the boats have natural bow lift as well as rocker built into the hull.
Now since he has started modifying XR drives he could have a SCX and space it down to stock propshaft height. The bigger gears would hold up better I feel. I'm going to save up some pennies and convert to an SCX-4 this winter.
Just my 2 cents.
Last edited by mickeymcclgn; 07-24-2014 at 11:45 PM. Reason: Spelled riks name wrong.
#47
Smiity I can't read thru your Anguish of Drives anymore my SON.
Look to thee Heavens and thy Lord may grant you the answers for all thee drives that have Betrayed you.
SMITTY my SON , One word ----- ARNESON
#48
Yeah sure, the stellings box then imco -2 shorty never worked so lets spend 2 more seasons re-rigging the boat and re-inventing the wheel trying to make a Arneson work!!! I wouldnt re-rig this boat with one at this point even if someone gave me one!!!! The boat runs high 90's, is fairly stable and goes past the 50 hour mark with gears and bearings these days thanks to the Neo oil so I will stick with that, Smitty
#50
I wouldnt bet money on it, the stuffs not magic, with stock hp or even 500 the stock oil still maintains a lubrication boundary , its when you get into extreme hp where the oil is squeezed out from between the two gear faces that using high dollar stuff, fancy will be a actual help , Smitty
