Bravo1 vin. help
My 1997 Bravo drives and transoms are OK xxxxxx so the OF's will be older.
http://www.mercruiserparts.com/selec..._nbr=BRAVO+ONE
Offshoreonly Advertiser
That comes up as a 1994 3.0LX engine, are you sure of the number?
Marc
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
No not sure, seller says numbers are hard to read, says it could be an OL code., I'm gonna look at it Monday, upper tooth count is 1;50
Thanks for all the help,
I have a lot of pics of the drive & internal parts, definitely a Bravo1 , 1;50 ratio upper gear tooth count, thin floor gears , looks good , the upper bearing went bad so the owner bought a rebuilt unit , will know more More after I see it.
OK, I inspected the Bravo1 today, it ,,OL,, Code, stamped very lightly and hard to see , used a magnifying glass to figure it out,, looks real good overall so I'm gonna install all new bearings/seals, etc. on upper & lower.
Thanks for all the Tech. help & info.
Mike
Mike
