What is the best tool to cut speaker openings?
Just have to ask what is your plan for the speaker placements? I don't see what you need the extra set of tweeters for, unless your 8.8 & 7.7's are going to be placed very low in the boat.
That system you have right there should make plenty of sound. The 10" may have a bit of a hard time keeping up with the four coaxial speakers, but should add some solid bass to the system.
Question, because I see you are pretty intelligent about the systems, what do you mean about the 2 10s keeping up?? I don't understand.
I would try to get the speakers up higher if at all possible. My system is 4 6.5" in the sides and 2 above the swim plat. Then three 12" subs under the bench. Anyone that has heard it will probably say it hits pretty good.
It's just that you have 4 mid/hi speakers and then the extra tweeters. That's a lot for the 10" to keep up with. The thing is with the speakers low in the cockpit you will not hear all of the output from those speakers.
My issue is that I am replacing existing 6x9 speakers and thus the holes are already there. I will have the 2 10s under the back seat bench and cut new holes for 2 7.7s next to them. Then in the front of the cockpit low I will replace the 6x9 with the 8.8s. And high in the front there are 2 tweeters that I will replace.
I can get a couple higher I think but they would have to be 6.5 I think. Would it help? How many and what size?
Thanks!
Our boat at the beach.
https://www.youtube.com/watch?v=6_Ix...ature=youtu.be
I use a holesaw,,not only a perfect hole but easier to get into a tight place than trying to wrangle a jigsaw around
interior pieces..
Remember the hole for a speaker is smaller than the listed size.. Example a 6.5" speaker
may only require a 5.5" hole.. The actual hole size will vary even among speakers listed as the same size.
interior pieces..
A buddy of mine has a 33 AT with almost the same set up. I think he has all 8.8's. I know he said if he did it all over again he wouldn't have put the subs in but would've added another pair of 8.8's. three pairs of 8.8's will put out more than enough extremely tight bass and sound amazing. Run them with a pair of class D amps like the Rockford's M400 or JL audios's M600 and you'll have the best sounding and loudest stereo on the lake. We used a Ridgid brand one handed reciprocating saw to cut the holes. works great and is around 100 bucks. Super light and very maneuverable as well. Hope this helps.
If those are 10W3's, they will not have any issues keeping up with the rest of the system.....I would've recommended more amp for them though if they are 10W3's....I also don't think you'll be happy with 100 watts on those 8.8's, they really need more juice than that to come alive. I would've done a 600/4 and 750/1 or for a little less cash an 800/8 and a 600/1, if they would make the XD1000/1 in a marine amp it would be perfect for those subs, but I wouldn't recommend them unless the boat is always in fresh water. I have run the standard XD's on numerous lake boats without issues. I actually prefer the XD amps over the HD amps on full range speakers as I can hear the amps switching through the speakers and if the ohm load gets below 1.7 or so the amps start to freak out. Since most of the boats I work on run 6 speakers, putting 4 of them on 2 channels cuts the ohm load down to 2 and it can easily dip below that depending on voltage and a number of other factors.
