Elims with Surface Drives?
arneson-industries.com
Offshoreonly Advertiser
We've done some 21', 24', 30', 36' and 40' Eliminators over the years.
There were no problems with any of the applications. Your power does not present a problem as we have sold drives to Ilmor for your sized engines on catamarn applications and have no failures.
We've got a few options on propellers and propeller types that you can use ranging from a standard Bravo style propeller to the Speedmaster propellers. All standard propellers that you are familiar with.
Did I mention you won't loose any speed with the Arnesons and we have a warranty
rik, ive always heard alot about the arnesons , are they as bulit proof as every one says , how long do they last before a rebuild , and which # arnesons do you recomend for 700hp
I've got a lot of applications with higher power than yours. 38 Top Gun with 1000's, 38' Scarab with 1,000's 388 Hustlers with 1,000's all with no problems and going on their 4-5th season. (All three boats were installed at the same shop, 388 told the Scarab, he told the Top Gun, all very happy) They sold them on a new 38 Donzi ZRC. 950 Sterlings, same #7M Kits.
Baring you running over something, they are pretty darn reliable.
You'd have no problems either.
Rik, can you email me any info you have on those drives and pricing , also if possible the name of the shop that did the work for the others , or a capable shop in the north east
The only thing I can remember about the Eliminator was the notched transom - We thought about it on the Hemi boat, but would need to fill and build the lower transom to use the surface drive - I spoke to Rik about this as he's familiar with the boat (Dustin Whipples old ride)
We ended up with BMAX's - they've performed very well.
One thing we discovered in the change was we ran the IMCO's at 1/2 shorter than stock (2 inch shorties with 1 1/2 spacers) When we installed the BMAX's with the same set up the boat didn't handle anything like before - to the point the owner was wanting to yank 'em and sell them immediately. We decided to try them at 2 inches shorter than stock vs. the 1/2 inch we were running and they worked beautifully. So far the drives have a ton of hrs and many many hard pulls and no problems to date. He's running 6 blade Herrings and I think 36 pitch ... but I can't remember all of them ....
We have Arneson's on an old Excutioner I ran yrs ago with 750hp - never had a problem till we "bumped" something and the tie bar broke ..... at about 80 ..... that makes a mess of a couple of cleavers ... beleive me.
Registered User
Good stuff right there...
The #7M's. I warranty (no b.s., no games ) them to 850 hp for one year.
Could you clear this with one or two of your clients and PM me their contact info - along with estimated pricing to do this conversion?
