Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
gel coat over paint / clear coat ?? >
Old 09-18-2007, 09:34 AM
Chris288's Avatar
Default gel coat over paint / clear coat ??
I scuffed up the bottom of my jet-ski pretty bad. I beleive the finish is black paint w/ clear over it. I think gel-coat is tougher and more scratch resistant and would like to spray it over the clear coat ?? will it work, if so what kind of prep is necessary, will it hold up. Thanks Chris..
Chris288 is offline
Old 09-18-2007, 03:58 PM
Charter Member #232
Audiofn's Avatar
I HIGHLY doubt that it is paint. You should be able to find out from the Manufacturer. I would not put Gel over paint.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-18-2007, 05:46 PM
no gel over paint, you must remove the paint first then gel, use 80 grit Da paper strip it then spray gel
CLIMAX is offline
Old 09-18-2007, 06:06 PM
Ditto, never spray gel over paint.
Brandon is offline
Old 09-19-2007, 08:26 AM
Chris288's Avatar
Thanks guys, will check and find out exactly what is currently on the bottom...
Chris288 is offline
Old 09-19-2007, 12:40 PM
Lakeside Restorations.com
Commercial Member
LAKESIDE RESTORATIONS's Avatar
If it is a Kawasaki or a Yamie they did use paint on some of them.. & yes they are right no gel over paint.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 09-20-2007, 03:29 PM
Chris288's Avatar
Jamie, I was under the impression it was paint, then somebody said gel, now you got me really confused. It's an 07 Kawi Ultra 250 ?????
Chris288 is offline
Old 09-20-2007, 04:31 PM
Commercial Member
I have done a good ammount of kawasakis.. I am pretty sure that it is paint on yours. Matter in fact I cant remember tha last Kawie that I did that wasnt.. The same with the Yammies.. Now SeaDoo was doing a lot of gel but then the hoods were usually paint.. It does cause for some confusion anymore.. They all kind of do thier own thing anymore & some mix & match..
Jamie / Lakeside
Zookeeper266
15
10-01-2013 08:23 PM
jeffbare
4
11-06-2007 09:24 AM
Fenderjack
14
02-14-2007 07:22 PM
betitbig
5
02-06-2006 04:39 PM
pb
7
08-24-2005 01:19 AM
Quick Reply: gel coat over paint / clear coat ??
