Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-18-2009, 08:41 PM   #1
Pokher Ace's Avatar
Fountain
Wet Sanding 101
Can someone please fill me in on the 'Basics' of wetsanding. I have a very good idea just need the reassurance. I have to wetsand and then buff faded boat numbers from stickers on a boat, and then a whole jet ski.
Pokher Ace is offline   Reply With Quote
Old 06-18-2009, 10:28 PM   #2
Neno the mind boggler
glassdave's Avatar
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
On gel you can start kind of coarse if you need to level the surface. Somewhere in the 600 to 800 range in the worst areas and step up from there to 1000 then 1500. Use slightly soapy water and just take your time with it. make sure to keep the surface and water clean and squeegee the surface often to check progress. Gel is very hard on paper so get plenty of it.
08 OPA High Points Champion
glassdave is offline   Reply With Quote
Sponsored Links
Old 06-20-2009, 10:34 AM   #3
marineclean's Avatar
12ft. Aluminum Canoe
The thread was kinda buried, but here you go. Lots of good input.
http://www.offshoreonly.com/forums/f...wetsanding+101
marineclean is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
