Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Hazy with machine - shines by hand!! >
Old 08-11-2009, 06:32 PM
Originally Posted by Jassman
read the thread, buff at 2000rpms use the right product, and you will obtain professional results..Jeff
Jeff, Maybe this will get his attention----to detail.
USE THE 3M PRODUCT CALLED PERFECT IT-------GOT IT!!!
ROTAX454 is offline
Old 08-12-2009, 09:36 PM
Agreed! Start with the 3M Fast Cut compound, if needed, then follow up with the Finess-It. Then on dark colored paint follow with the 3M Ultrafina. When it comes to polishing products absolutley nothing can compare to the 3M products, nothing, I have tried them all and 3M is the best. Follow the instructions, use the right pads and you will have excellent results. This does assume you understand how to work a buffer, no way should your hand work be better than a rotary buffer if used correctly.
Just read your first post again, an orbital is ment to put on wax, not to be used with compounds and polishing material. You need a variable speed buffer, like a DeWalt, to get real results with compounds. The orbital just won't cut it, no pun intended.
RaggedEdge is offline
