Silent Thunder rattle?
Re: Silent Thunder rattle?
Originally Posted by formuladude312
Yes, It will sound better, I did this on my 272 sr1 and it gave it a nice rumble, you can do asearch on silent thunder and find the thread that tells you how to do it, I did mine by drilling 3 holes in the top 2 corners and the middle top of the baffle, and then used a keyhole saw, to cut across and then down to cut them out, it is easier to get the piece out by cutting it in half to get it back out thru your exhaust opening, Some people have also used a sawzall, but i found it easier with the keyhole saw, mine had a 12" blade.
I have the 4 drain plugs out and the baffles have 5 holes each cut in them.
SHOULD I PUT THE 4 PLUGS IN THE BOTTOM OF THE PLATFORM BACK IN?
I would put the plugs back in and remove the rest of the baffles
Originally Posted by offthefront
my only problem with that is you then build up water in the box ....how much I'm not sure .....but its more weight and more important is that box of water ending up back in the motor ...
With the plugs out and not having any water in there can create quite a bit of heat in the box and create fiberglass problems along with melting the flaps that are on the transom tips.
I found on my 272 that i had much better flow with no baffles and removed the flaps on the square openings in the back of the silent thunder box.
Hey guys,
Learned a hard lesson about the rubber flaps and removing them. My 1987 F206 was the first year with the silent thunder platform. The factory did NOT put on the square flaps on the back of the platform that year. There are actually round rubber baffles on regular transom tips inside the platform but the cannot be seen unless the platform is off the boat. You can also not see if the round rubber flappers break and fall off! In 1988 Formula put the second set of flaps on the back of the platform for a reason. About 6 years in, unbenownst to me, one of the round flappers broke off and apparently exited the platform. One day at the local sand bar someone pushed my boat backwards to get me out of the raft of boats and out into deep water to leave. Instant hydrolock of the engine. Bent two rods, collapsed an exhaust valve into the head, and cracked a piston. The purpose of those square flaps on the back of the platform is to help prevent hydrolock. There is negligible backpressure if any to the exhaust system. I'd leave any flappers ON! Drill bigger holes in the bottom of the platform to relieve backpressure.
