Upgrades to your Formula! What have you done?
#41
Where To
Still to come...This year:
- Stereo upgrade
- Finish the 2010 cockpit upgrade with carpet and dash
- 2010 Interior upgrade of the Cabin.
Stay tuned!
Dave
- Stereo upgrade
Stay tuned!
Dave
#42
Wow, nice work on the 271.
I also have a 95 271.
I assume yours had a silent thunder box that was removed and replaced with mufflers.
Did you need to replace the thru hull flanges to install the mufflers or did the mufflers in the pic fit over the origionals.
The spouts on my thru hulls have a small lip on the end that would make it hard to seal a muffler against water,
How did you do yours??
1995 271 Indy
1. 575SCi w/ bits powdercoated to mimic the original engine's color theme
2. Imco Transom Assembly
3. Bravo XR
4. CMI E-Tops w/ 6" rise
5. GGB Mufflers
6. Latham strainer
7. Imco water pickup
8. Latham helm
9. Livorsi gauges mounted in new dash panels
10. All the hardware needed to hook the stuff up
3. Bravo XR
5. GGB Mufflers
6. Latham strainer
8. Latham helm
#43
Yes, the Silent Thunder box was removed, as well as the original tailpipes. The mufflers that were fitted are the bolt on type that have a 5/16 stud every 120 degrees that requires a hole to be drilled through the transom for each stud. The original cast tailpipes are held to the transom with self tapping screws, and due to their shape, I don't think there is a clamp on/slip on muffler that will work with them.
The holes that the ST box left behind, I used ss carriage bolts with the heads powdercoated white for the transom, and used ss buttonhead cap screws/washers powdercoated white to fill the threaded inserts on the underside of the platform. Also, the studs that hold the ladder down were shortened to keep from harpooning someone.
A couple of pictures to illustrate the explanation.
#44
Mine is a work in progress and I just got my dash and switch panels back today. Here is some before and after pics. I bought the Livorsi Momo wheel and had the panels paint matched also got all new gauges from them. Having the sticks chrome powder coated with blue tops and the drive indicator bezel chrome also. I will post more as I get further.
Has anyone in a 1997 replaced there glove box hatch with billet? I was thinking about doing that to improve that side!
#45
Here is a project I did in 2005. It was fun to do. Craig Barry rode on my boat from Mission Bay to San Diego......he said it just needed a little bit more power......Craig is a smart guy.
#48
Thanx for the info, I fiqured the orgional tail pipes
would need to go.
Nice boat, incredible condition.
would need to go.
