The cooler drains is a mystery in Fountains. Mine drained into the gas tank cavity, but I never used it anyways. Some drain in the side stringers drainage, then into the bilge. The cockpit drains drain the same way. The holes going into the bilge are on the outside of the outer stringers underneath the battery trays. I ran a drain hose from the cooler drain fitting, directly into the bilge, eliminating the free flowing thru the bottom of the hull incase I wanted to use the cooler. Might try not using the cooler or hosing the cockpit out and see if your water problem goes away.
