Speed rpms and pitch 27 Fever????? >
Old 02-20-2008, 05:45 PM
Default Speed rpms and pitch 27 Fever?????
I 'm getting ready to splash my 27 as soon as I can..I was just checking with Fountain valley to figure out what i should expect or compare notes with the boy's.
I'm runnin' a 502 between 5 and 600 HP on a non stepped 92 27.
Any experience like prop types and contrasting speed and rpm would be nice to know if anyone is so inclined..
I got a mach stern driver 15X25 4 blade. I heard they are not the best. Any info would be sweet.
mcprodesign is offline
Old 02-20-2008, 05:57 PM
I had a 502 pushing 670hp and I ran a 28 4 blade bravo. I was a stepped bottom and it ran 84 and cruised at 45, (3000rpm)
apppedigree is offline
Old 02-20-2008, 06:02 PM
Thanks for your reply.I was kinda hopin' to hear from you.
How many R's at WOT?
Old 02-20-2008, 07:06 PM
Charter Member # 545
Beak Boater's Avatar
What RPM and gear ratio are you running. Bravo 1 will be hard to beat as an all around good wheel. Ran Hydromotive props on our stepped bottom 27. Box stock the Hydro was faster, cavitated more getting on plane. Best of both worlds get Brett at BBlades to lab a Bravo 1, once you figure out your RPMs and gear ratio.
Beak Boater is offline
Old 02-20-2008, 07:16 PM
I want to say the RPM's at WOT were 5600 - trimmed out to 3.5 on the gauge (I know that is not much trim but the boat liked it the best - and I like to live)
Hydromotive was hard to plane off and did not give enough bow lift. I had a 1:5:0 bravo one with the standard IMCO nose cone. All my props had the difuser ring on them as well.
Old 02-20-2008, 09:07 PM
SeaRay Sundancer
tblrklakemo's Avatar
Yup, my fever likes 3-3.5 (level) drive settings. I hear most like level-ish.
tblrklakemo is offline
Old 02-22-2008, 02:40 PM
Registered User
bcfountain's Avatar
Default 27speeds
my 94 27fever has a 502mag,mpiw/a mach driver 24leftrotation.speed w/that prop and trimed to3.5-4 on the gage ran about 64-65 on gps.i changed to a bravo1 26leftey and picked up2mph at a lower rpm5100 comparied to the 26 at 4800rpm.the hull is a non-steped hull.hope this helps.
bcfountain is offline
fountain1998
Fountain
34
02-21-2006 06:09 PM
VeeCat
Hustler
33
07-19-2005 09:39 PM
electrical1
1
07-18-2004 12:59 AM
DaveP
12-15-2002 10:20 AM
jdnca1
13
02-28-2002 05:47 PM
Quick Reply: Speed rpms and pitch 27 Fever?????
