Props
If you call or email fountain with the hull number you can ask for the original test report sheet. It will have all the info you you need including speeds/rpm, weather report, engines, drives, serial numbers, and props used. I emailed them last August and they emailed it to me within 2 days.
I run 26 pitch hydro quad 4s with 1/2 inch pitch removed to 25.5 and lab finished by hydromotive on a much heavier boat to about 4900 with 425 HPs. My guess is 27s lab finished?
