Dry sump vs. Wet sump #6s
How much difference in speed are the 2 drives?What is the sweptback skeg worth over the wet sump skeg?I have heard alot of #s but has anyone backed to back the drives?
Re: Dry sump vs. Wet sump #6s
:D :evilb: :drink: :evilb: |
Dry Sump Drives Are The Way To Go ///Uses Less HP Than The Wet Sump///// No If Ands Or Butts///go with a dry sump
Originally Posted by blastersbro
dont worry you will have one to test back to back with soon enough. :cool:
i thought you knew everything...
From my understanding at least 5 mph. However, it depends on your prop set up as well. If you are already at the rev limiters you will see zip improvement.
I read somewhere that the swept skeg really only helps at high speeds, 95-100 +.... And on lake champlain at that speed you were hardly in the water and Byrd was holding on for dear life...:D
I do ............almost :D
i better ask z all my important questions...... |
