If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
  1. #1
    My Boats:
    29 Fountain
    Join Date
    Nov 2006
    Corona, CA
    I had a pulley go out, help!
    I had this pulley on the black plate go out and need to replace it? Would this be considered the idler pulley or something else? The pulley doesn't really do anything, just help's to guide the belt because of the water cross over. Thanks for your help.
  2. #2
    VIP Member VIP Member offshoredrillin's Avatar
    My Boats:
    00 Cig Tiger,74 Cig 20'
    Join Date
    Feb 2004
    typically that would be a water pump pulley, but as you dont have one it just has the plate.the 4 bolts generally go onto the front of the water pump. it should be an easy fix, just make sure the offset is the same, as some are recessed around the snout of the pump. Actually looking at the pic closer, it seems that it may have the snout of a water pump or fan bearing assembly bolted to the plate. if so you should be able to locate one of them and reuse the pulley.
  3. #3
    instigator Platinum Member BUIZILLA's Avatar
    My Boats:
    1980 Donzi Criterion 22
    Join Date
    May 2003
    Miami, Fla
    isn't that fuel line awfully close to the belt??
Similar Threads
  1. Need whipple crank pulley 502mpi - Surpintine/v-belt pulley
    By poolshrk in forum General Boating Discussion
    Last Post: 04-06-2008, 11:34 AM
  2. Alternator Pulley
    By BigFish in forum General Q & A
    Last Post: 12-02-2007, 04:26 AM
  3. Whipple pulley?
    By JasonSmith in forum General Q & A
    Last Post: 09-19-2007, 07:37 PM
  4. pulley sizes
    By CHAOS REIGNS in forum General Boating Discussion
    Last Post: 04-13-2004, 08:12 AM
  5. where can i get a pulley
    By CHAOS REIGNS in forum General Q & A
    Last Post: 04-11-2004, 07:52 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
