speedo not working
Old 04-07-2009, 11:23 AM
Default speedo not working
Any ideas how to try and fix? bravo ones.
brian18330 is offline
Old 04-07-2009, 11:25 AM
PhantomChaos's Avatar
Usually there is a rubber hose that popped off. Take a look around your drive.
PhantomChaos is offline
Old 04-07-2009, 12:04 PM
Received 1,821 Likes on 907 Posts
The speedo pick up on the leading edge of the lower unit is probably plugged. Its a little notch about 4" above the bullet. The actual pick up tube could be connected to either drive.
Griff is offline
Old 04-07-2009, 02:48 PM
Quinlan's Avatar
That was always my problem. Take the smallest drill bit you have and start w that. prob some wood in there.
Quinlan is offline
Old 04-07-2009, 05:19 PM
johnnyboatman's Avatar
LEAVE IT PLUGGED, MAKES THE BOAT FASTER
johnnyboatman is offline
Old 04-07-2009, 06:47 PM
Pickup tube is either plugged or cracked, and may need replacing. I had the same problem, mine was cracked, and had to splice the hose and refit together with hose barb.
07DominatorSS is offline
Old 04-07-2009, 08:32 PM
scottw's Avatar
I agree with griff. Proabably some wood in the pitote hole.
scottw is offline
Old 04-07-2009, 10:02 PM
OkieTunnel's Avatar
Speedo is fine...you just need more power
OkieTunnel is offline
Old 04-08-2009, 09:37 AM
My speedo didn't work for me either....
So I switched to boxers
Flaker is offline
Old 04-08-2009, 10:41 AM
Jigsaw89's Avatar
Thumbs up
If the little rubber hose didn't pop off as Phantom Chaos advised then I would do as Griff suggested. I had the same issue last year and corrected it by pulling the drive and using a long thin drill bit to clear debris from the lower unit speedo pickup and it's vertical capilary where the rubber hose connects... problem solved!
Jigsaw89 is offline
