Got a serious problem I think... need advice...
1 Post
Well, I have been detailing the boat for hours. And I was spraying the floor down with the garden hose as I was scrubbing it. Then I moved onto the vinyl cleaning...
Well when I opened the hatch to get some areas that were covered, I discovered this...
There is water between the stringers, and it doesn't go anywhere. I am assuming water is not supposed to get in there. And as you can tell, the water on the port side stringers sure seems to have some balsa floating in it.
What do I do?
What do I do?
I'd pump it out or sponge it out and then start looking for any clogged drains or anyplace the water may be coming from. If it sits there too long you can start to have it soak into the stringers.
Just curious did you just wash the inside of the boat or the boat in general or may be it might be some rain water from sitting, being it is the first time you opened the hatch. Just an idea.
1 Post
Then a few hours later I noticed the water sitting in there.
1 Post
The water in there is from me washing the deck.
What I want to know is: Is the water supposed to drain in between the stingers like that? If so, why is the water just sitting there and not draining completely into the bilge? Is there supposed to be drains between those little channels, or is water never supposed to be in there in the first place?
That depends on how it was originally designed. Generally stringers have holes cut in them near the rear bottom of them for water to drain. From all the crap floating in there, they might be clogged.
I just have to wonder how all the water got in just from washing the deck. It really shouldn't. The only thing I can think of is that it came from your pop up cleats.
1 Post
I just did not know if this was normal.
I would say yes this should be normal for how you washed the inside of the boat. If you look to the rear of the boat along the stringers you might see some holes that should be drains. some times you will need to lift the bow up to get it to drain. If you have no holes you might be able to add some holes to it some day if it looks safe to do it.
