poof !
Sunshadow, one thing to know about OSO, particularly the GD area is it feeds on drama. I used to refer to GD as the Jerry Springer show. I've been here a long time and seen a lot. Don't let any of this rub you wrong, really. Its all good.
As for JDUB, well he 's a ho. A ho thats not been blueprinted
BT
BT
BT
BT
I'm hunting a cheap 32-42' cruiser jdub. Know of any around the area?
Member #154
Just a few thoughts on this thread:
>Glad you got resolution.
>I think you posted this thread in part to get opinions and in part hoping he saw this and it motivated him to settle.
>I'm sure a few here seem to feel that they got used for your own benefit.
>The seller did not act with the interests of his client, but for his own benefit since he had no problem cashing the check.
>It's possible he was just going to screw you had you not pressed the issue on OSO which means that he has acted like this before and probably will again.
>Many here are upset that they won't know who to avoid in the future since you got the outcome you wanted.
Relationships on this board (at least in the old days) are strong from a community standpoint. We tend(ed) to look out for each other since this business seems to be permeated with scumbags with little or no integrity. The fact that we were quite possibly used has rankled a few feathers since one of the reasons we frequent or belong to sites like these are to look out for each other and lend a hand when necessary. Many have been outed before and the community is all the better for it, I know for a fact that it has saved many headaches and some real dirtbags have been exposed. Too bad this incident will remain between the two of you.
Look man, I'm glad you got it resolved...really....this hobby/sport is expensive enough as it is. To have somebody string you along or screw you over only adds to this expense.
You say you made the seller aware of the thread...do you think that had anything to do with the problem being solved?.....wait don't answer....a simple "thank you" to the OSO community will be fine
