Hats off to Howard Arneson!
- Inventor - Performance Boating, Record Breaker/Record Maker - Never met him but from what I have read about Mr. Areson, a true Gentalman. |
Was considering starting a new thread but found this. Such a cool story.
For discussion's sake, can/will this record be broken with modern performance or did Howard reach the limits of safety at speed on the Mississippi for that long of a run? Seems a bit of good fortune is certainly a big variable. Thoughts? BTW, original link is gone, but great write-up of the event here: http://www.howardarneson.com/articles/fireonmiss.asp |
personally, i think today's boats, and engines could do it, however the biggest x factor would be the barge traffic, and the how fast you could really go, I think that if you had a helicopter scouting, i don't see why not.
The river channel is wide and plenty of room to run. The caveat would be time thru the locks. The large waves are directly behind the tow boat so I don't see that being an issue.
awesome units! Waiting to hear an update on that multispeed, quick change gear ratio unit
Originally Posted by Keytime
(Post 4330645)
Thoughts? |
Got a timeframe, Tyson?
Definitely seems like some luck will be involved. Be safe. Will you do the LOTO D2D2D in this boat as well for ****s and grins? |
Originally Posted by endeavor1
(Post 4330707)
Originally Posted by Plowtownmissile
(Post 4330860)
If memory serves me right, there are no locks below St. Louis so there wouldn't be any locks to go through.
(Post 4330862)
Guess I need to see where the record is to and from. I'm used to boating in pool 18/19 on the upper. I thought the record was upper and lower Mississippi River but if it's just the lower then you are 100% correct PTM.
