Leave it in the sun for about a week.
Maybe try Spray Nine, it works great.
Mineral Spirits.
Maybe try hairspray or lysol, I know it takes off permanent marker. |
Run by Advance Auto; swing thru the rice-a-roni aisle, and stick a leather wrap on that bad boy. :D
i would try wd40 or carb cleaner but use the carb cleaner lightly --simialar to lacquer thinner
soak some bleach on a wash cloth. set it on the stain and leave it on the stain over night. the bleach will pull out the ink
Originally Posted by Sydwayz
(Post 3488160)
(Post 3488160)
I actually painted the steering wheel on my 98 formula. The paint I used was Rustoleum vinyl paint. Worked great.
After using all the aforementioned products, it will have dissolved the vinyl leaving you with the frame only and you're problem is solved!
