Best wax and buffer??
Porter Cable 7424xp for your machine.
The Meguiar's Microfiber Correction System is the hottest thing out right now. The cutting discs are more aggressive than a regular foam pad and the finishing disc also flattens the clear coat more than a foam pad so you end up with greater clarity.
I figure you'll want the 6" disc kit for a boat since you'll have to cover a lot of surface area.
http://www.autogeek.net/da-microfibe...r-kit-6in.html
You'll want a sealant/wax. I have and love the Adam's Machine Super Sealant. You'll want a pad to apply this so you'll want a pad to apply the sealant:
http://www.chemicalguys.com/Lake_Cou...uflc_105_6.htm
Make sure you wipe off all residue with an IPA wipe down (50% rubbing alcohol and 50% water) or wash the boat again with Dawn to remove all polishing residue before you apply the sealant to make sure it bonds with the paint properly. Let it sit on the boat for 30 minutes and then remove.
http://www.adamspolishes.com/p-139-a...r-sealant.aspx
