Solid engine mount alignment question.
Never really have to change alignment when swapping engines unless it was off to start with. GM blocks are all pretty much the same. Adding washers to the back mounts is definitely not the way to
align the engine. If you have to do that something is wrong with the mounts.
Good luck.
Eddie
