Mph lost goin to b max drive from xr drive >
Old 04-04-2015, 03:28 PM
Rob
Strip Poker 388's Avatar
My Hustler came with xr 1.50 30p bravo one 4blades, previous owner switched to bmax 1.30 gear and 24pt bravo one 4 blades,same top rpm's, \..From what the boat ran new and what it ran when i got it, was about 2mph, now there could be other factors to, Hustler says the boat is faster with 1.50 and 30. over a xr w/ 1.36 w/ stock power. I added Whipples and went from the 24 turning 5300 to 30's turning 6000.and 32's turned 57-5800,high prop slip.
I would say if your using the Imco lowers that there would not be much speed difference.Also im guessing the imco is more hydrodynamic.My old version bmax lowers was real ruff,I have worked it a bunch and prob didnt help it.
Like they say about I think the main diff in efficiency would be form the gear change
Also I think it depends on if its a v or a cat at 120mph+
if mine is slower from using a more durable drive,its worth a few mph
Thats my opinion
goodluck
Rob
Strip Poker 388 is offline
Old 04-04-2015, 03:43 PM
Thats my opinion
goodluck
Rob
What were your slip #s on the 32? and the 30?
abones is offline
Old 04-04-2015, 04:20 PM
Rob
the stock 30's were around 18, speed was 102 at 6000,I never figured the 32,32's made one pass at 102 at 5700,The 28's ran 99.8 at 6000 on low boost
I tried turning in the 30's it ran 105 at 6000.
all above non labbed
I just bought some herring 5bd 28, it was a little sluggish,never GPS it over 100,I just got them back from Bblades as he reworked them and loosened them up,I wanted about 300rpm .
hope this helps
Rob
Old 04-04-2015, 04:49 PM
hope this helps
Rob
Yes that is good info Thanks!
abones is offline
Old 04-04-2015, 06:10 PM
As long as it's propped correctly for the new ratio, you shouldn't lose anything. I went from XRs to Bmaxs on my Spectre cat and my speed wasn't noticable. 118.5 with the XRs in cooler temps and 117.8 in hot temps with the Bmaxs. Didn't get a chance to test the Bmaxs in the cooler temps before selling the boat.
This is of course with the new style Bmaxs by John. He is continually improving the design of the case, he has also been working on a better lower case.
QWKRN U is offline
Old 04-04-2015, 11:04 PM
Very glad to hear that the new owner of b max has done a 180 with the company. I wish there was a few more companies that would give merc a run for their money.
cig92 is offline
Old 04-04-2015, 11:31 PM
B-Stubb's Avatar
Im betting 8-10 mph most people were unhappy
B-Stubb is offline
Old 04-12-2015, 12:28 AM
i will let yall know the results when they are on the boat and running
slippy0217 is offline
Old 04-12-2015, 08:18 AM
Did you buy new or used drives?
endeavor1 is online now
