What happens when you brake a drive in a twin? >
Old 01-24-2003, 08:21 PM
rbtnt's Avatar
I lost a motor (non P/S side) on 28 Daytona @ 90 and it was very easy to control. I was several miles from the trailer and 95 degrees out, so I let it slow down to 40 and ran it back to the dock on one. Ended up being a loose coil wire. Fixed before we got to the dock.
Wasn't there a race a few years ago where the leader blew a drive or motor on a twin and the team was putting a small prop on the good side as another boat took the lead, but the new leader ended up breaking too and the first boat was able to get on plane with a small single prop and win the race?
rbtnt is offline
Old 01-24-2003, 09:46 PM
lost a motor at about 75 mph but i have p/s on both motors and lathum to the wheel. Just noticed boat starting to slow down looked at tach and saw 0. Pick up in distributor went bad.
Mike 35 Fountain is offline
Old 01-24-2003, 10:58 PM
1HYPER1's Avatar
IF YOU HAVE A CAT,HOLD ON & GET READY FOR A VIOLANT
TURN ONE WAY OR YHE OTHER.
IF IT IS A V BOTTOM,YOU WILL FEEL A SLIGHT PULL,BUT IT
WILL BE CONTROLABLE.HOPE IT NEVER HAPPENS TO YOU
KNOW MATTER WHAT YOU ARE RIDING IN.
1HYPER1 is offline
Old 01-25-2003, 01:28 AM
had a express cat at 110 let go a mtr all i could do to keep it straight.needed new shorts when it was over!!!!
46tomcat is offline
Old 01-25-2003, 01:24 PM
SR-24's Avatar
I'm with 1hyper1, I don't want to know what happens. Thanks for all the input.
SR-24 is offline
Old 01-25-2003, 03:16 PM
HyperBaja's Avatar
Originally posted by packinair
I was running one night at just alittle over 80 at about 2:30am with the boat aired to the moon going under a bridge, lost my left motor just as I put the coals to it, ever drop an anchor off the port side with attatched to your front side cleat is about the best way to describe it..... I came within about 3 feet of hitting the bridge and just kept the throttle down so I would not come of plane (I can still run over 50 on 1 with the other dragging) and started started mixing captains.. scarry as hell
Is there ever a time that that boat isnt aired to the moon?
HyperBaja is offline
Old 01-25-2003, 11:43 PM
artselectricinc.com
Steve H's Avatar
I didnt blow up or break anything, but I thought that I did. about 5 years ago I was cruising about 50 in my 38 special. out of the blue the port motor over revved and the boat did a sharp turn to port. It had turned past 90 degrees before I could even reach the throttles. Got her stopped, lifted the drive expected something very bad, Found a big old board had hung up on the port drive. The sudden drag combined with zero thrust made it turn like it had a mind of its own. Could have been dangerous, but as usual I lucked out again.
Steve H is offline
THE OUTLAW
Drives and Lower Units
8
06-11-2008 12:07 PM
customryder
07-18-2005 01:17 PM
LHC30Victory
6
12-29-2003 11:42 AM
Wally
12-06-2003 04:52 PM
rbtnt
0
05-05-2003 10:07 PM
Quick Reply: What happens when you brake a drive in a twin?
