Prop help.
Prop Selection Cig Bullet
Found these numbers on the prop. HC CL 22 L QIV & HC CL 22R QIV. They are 4 blade stainless steel. What brand are they? They are on an 88 Cig Bullet.
Location: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
1 Post
Re: Prop help Cig Bullet
Originally Posted by gripit
If I wanted to upgrade, what would be your reccomendations.
Are those TRS drives you running in that Bullet? What rpm and speed are you getting with a light load on those props and at what rpm do you need to run your engine package w0t?
Originally Posted by GoCiggie31
Gripit,
Re: Prop help.
Can you tell me about your performance numbers.
What motors do you have?
What is your WOT RPM with the 22P QIV's?
What is your WOT MPH via GPS?
What is your gear ratio?
Julie
Julie
1 Post
Yes, they are TRS Drives. I'm getting about 60 mph with half fuel tanks. I have 420 HP's but don't know what rpm I need to run my engine at wot.
I would guess your gear ratio (unless changed is 1:5) what rpms do you run at wide open throttle when you have those hydros installed?
MIKEHTMSR24
07-22-2002 03:18 PM
