Speedmaster Tranny Question
can you use a 72c transmission? What would the difference between the TRS and Speedmaster be?
Thanks again OSO for putting up with all my newbie questions...
Re: Speedmaster Tranny Question
What is your application? What kind of drive do you have? Do you use a drive shaft or is your transmission "plugged in" to the transom housing?
The Merc TRS transmission is not the same as the Warner 72C.
Due
Due
The 72c is longer {I think 1" ?}....Speedmasters {3a & 5} were rated for 750 hp...TRS 525hp...Much stronger.
If you have TRS...Look at Konrad drive & Huber HM800 trans.{71c case}
I have a project in the works and just curious to the differences. Mainly the tailstock and input shaft differences in the drive to tranny.
