Hand pump for Amsoil Outdrive Oil
Registered User
Re: Hand pump for Amsoil Outdrive Oil
HERE IS AN IDEA I'VE BEEN USING FOR YEARS WITH GEAR LUBE AND SUCH
USE AN OLDSTAINLESS STEEL FIRE EXHUSTINSER
LET AIR OUT FIRES IE VALVE THEN TAKE WATER OUT ADD OIL AND PRESSURIZE IT AND IT WILL WORK. NO MORE PUMPING.
I bought a 48 ounce universal sprayer from Ace for $10. I removed the hose and fitting from my Merc pump and connected that to the sprayer. Great idea worked much better and faster than the hand pump. I also used the 5 gallon bucket trick for the RV antifreeze. That was a lot better and easier than removing all the hoses and hoping it got in all the right places.
Thanks for the tips guys!
Jeff
Jeff
SneakyPete
Drives and Lower Units
9
04-10-2008 09:45 PM
