AMSOIL out drive oil,,, which one.. >
Old 08-04-2004 | 01:14 PM
Chris288's Avatar
Default AMSOIL out drive oil,,, which one..
Am going to go with the amsoil synthetic gear lube for my bravo 1 drive,, they have about 5 different ones, including a marine one,,, which one should I go with,, which one did TEAGUE reccomend in his article a few monts back.. ? thanks Chris..
Chris288 is offline
Old 08-04-2004 | 01:24 PM
Default Re: AMSOIL out drive oil,,, which one..
http://www.powerboatmagazine.com/tea...es/2002/07.php
NightHawk is offline
Old 08-04-2004 | 01:50 PM
Chris288's Avatar
Thanks Hawk..
Chris288 is offline
Old 08-04-2004 | 05:09 PM
I've been using the 80w90 marine stuff for the
last 3 seasons.........No malfunctions
jt
JaayTeee is offline
Old 08-04-2004 | 06:37 PM
Hydrocruiser's Avatar
Arrow Re: AMSOIL out drive oil,,, which one..
I spoke with AMSOIL reps yesterday about their gear lubes. They make 4- gear lubes that can be used in lower drives and one is labeled "Marine Gearlube"
Here are the 4 products all of which you can use depending on application I was told:
1.) Their best 75W formulation is 75W-90 Load rated GL-2 - GL-5, MT-1
Product code: AGR It has the highest heat corrosion and antifoaming additives of the bunch.
2.) 80W-90 GL-2 - GL5, MT1 Their best 80W formulation Amsoil product code AGL.
3.) 80W-90 GL-4 rated, MT1 Amsoil AGT/ALU
4.) Marine 80w-90 GL-4 NOT for GL-5 manufacturers specs. Codes ALU,AGT
Amsoil has a tendency to label similiar products for "Specific Uses" by maybe changing additive packages. It can be challenging to sort through it all.
Now when I called Merc and asked what "HP" is rated at; they did not know for certain; but many non "HP" formulations are rated only GL-4 and HP is a better formulation as it has antimony (a metal powder additive) to cushion gears. To be safe use a GL-5 product to replace "HP" is what a mechanic told me was the only way to go. That would be AMSOIL "AGL"
You can go with either 75W-90 or 80W-90 according to my mechanic as well.
Redline 75W-90 "SuperLight Shockproof" Gearlube is rated at GL-6 it is made for the heaviest loads and is the best product out there. It does cost 2x ( About $12.00/qt but you don't need all that much.) This is what I am going to switch to as it can handle heat, stress and load better than anyother product other than Mobil-1 which is a close second as it exceeds GL-5 but not quite a GL-6.
Royal Purple's best is MAX Gear and is a GL-5
Mobil-1 Gearlube exceeds GL-5 and is a bargain for it's price!
So Redline and Mobil offer the highest rated synthetic gearlubes.
After a month of research I am finally where I was hoping to be with oil,gearlube and oil fliters..
1.) Mobil-1 20W-50 V-Twin Synthetic is the best rated of the bunch and almost tied with Redline. Amsoil Series 2000 Severe Service is a close #3.
2.) Redline Gearlube has a slight advantage to Mobil-1 but they are both significantly ahead of the pack in load ratings.
3.) Baldwin, (Amsoil which is a Baldwin) and Mobil-1 make the best trapping and flowing oil fliters. An A/C filter is very good for a budget oil fliter.
Attached Thumbnails AMSOIL out drive oil,,, which one..-85.jpg   AMSOIL out drive oil,,, which one..-agl_qt_300pxh.jpg
Hydrocruiser is offline
Old 08-04-2004 | 10:22 PM
p4-33's Avatar
Hydro, do you DRINK this stuff too? I've never met anyone with the knowledge of oils and lubes that you've gathered up.
Just awesome.
Brian
p4-33 is offline
Old 08-04-2004 | 10:24 PM
p4-33's Avatar
P.S. How's the buzz?
p4-33 is offline
Old 08-05-2004 | 09:02 AM
Chris288's Avatar
Thanks for the info, went with Amsoil agl,,,, you would think that the MARINE lube would be higher rated than just a GL-4 ??
Chris288 is offline
Old 08-05-2004 | 09:12 AM
I didn't leave a "stone unturned" in doing this research over the last month. If you don't know the bottom line you may use a product based on some form of advertising or tests that don't mean anything like the 4-ball scar tests. Meaningless is what a government report said in applying the data to engine wear.
Good info is what we have now for practical considerations of what product(s) to use, using at least a GL-5 or better in a Bravo is the way to go.
Old 08-05-2004 | 09:22 AM
One would think that would be the case in that Amsoil Marine would be GL-5 rated to replace HP or be rated higher than Merc HP. It's just that HP is a semi-synthetic product and a very good product. So you need a heavy duty synthetic to equal or match it. If you go with a GL-5 synthetic you probably will get similar performance to Merc's HP. Going to Redline Gearlube rated at GL-6 is a different story. That's the way I look at it anyways. Of course a GL-5 synthetic can take more heat than a GL-5 conventional. So there is an advantage of going GL-5 synthetic. Amsoil just says not to use their Marine lube if you need a GL-5 rating and HP is close to if not GL-5.
Next time you might want to go with Amsoil's Gl-5 if you want to stick with Amsoil. I went Mobil because it exceeds GL-5 is cheaper and easier to get with no shipping costs. At the time I didn't know Redling was at GL-6 because a GL-4 vs a GL-6 means the GL-6 has 34% more load bearing capability and gear protection. A GL-6 vs a GL-5 shows the GL-6 has a 20% advantage and that's still a lot! Drives repairs are expensive and this GL-6 lube will cut repair bills!
The entire line of Redline oil and Gearlubes is superior to most. Mobil-1 and Amsoil are more similiar than different if you review the data. Royal Purple makes a GL-5 gearlube but their oils have much lower VI's meaning they don't hold viscosity under heat as well. They are similiar to synblends.
