Shift interrup 6.2MX
Re: Shift interrup 6.2MX
Today I checked a 4.3 EFI with MEFI3 Ecm at the shop I work.
If pussing Interrupt:
Status changes from OFF to ON.
Timing drops to about -20 for a split second.
IAC closes a bit more.
At my engine, no effect. So I need to reprogram the ECU or an alternative thing. Are there some pioneers who tried the same?
Richard
Richard
I used the red/white wire, and the newer normally closed switch to interupt the power to the coil, which is similar to the old carb way of grounding the coil.
Tested it, if I touch the switch for more than an instant it kills the motor.
