where to buy isky red zones or crower severe duty
#41
Geronimo36
Steel. My cam isn't as hot as yours though; http://www.cranecams.com/?show=brows...31&lvl=2&prt=5
Cam card calls for 0.20, we set the lash .14 hot. Ran 60 hours last year, just pulled the intake manifold off Saturday to inspect the cam/lifters/pushrods etc...barely any sign of wear. It's time to lash again and go another season.
#42
#43
Charter Member #601
Ok Mike, so you are saying that u are setting them Hot at .018" when they call for .025"... Interesting!! What ever makes them live.. that's what I am looking for.
Dick
Dick
#44
Is the purpose of setting the lash tighter to keep the launch on the backside to a smaller dimension?
Either way, easy enough to do and I am with Mr Gadgets, anything to make them live.
#45
Geronimo36
As a matter of fact I've always done it, even with the solid flat tappet cams I had in my Scarab!
A while back I usually went .002 tighter on the intake than the exhaust, my thinking was the hot exhaust valve would grow more than the intake. Seems these days a lot of the manufacturers go even on both.
#46
Charter Member #601
Took my cam to the tool and die shop, did a rockwell test on it. Tested in several places, hard to get a cam in the fixture, but areas that showed little wear were 61-62. Top of one lobe, severe damage, had 58. So I dont believe the cam was the problem.
Still havent had a chance to check valve tips.. next step.
Thanks Guys!
Dick
Thanks Guys!
Dick
#48
