Suggestions Please - Crank Case Venting
I have the standard crank case vent hose that is routed back to the throttlebody. Needless to say, the intake gets a constant coating of oil from either minimum blow by and/or oil pan windage...
Is there a nice looking can that can be purchased to capture or filter this? I want something that is nice looking as well as functional. I'm picturing a real small version of a nice sea strainer with a billet top or something that matches engine colors.....
I would think something along the lines of a aluminum can/box with mesh (like course srubbing pads) and then vented to the intake after filtered....and a way to drain would work....been thinking about something along those lines well...Rob
Airking
Stef Puke tanks
Here are 2 Stef crankcase vents puke tanks. They have drains and are set up with AN fittings for stainless line and BBC mounting brackets. Will bolt to top bell housing bolts. You can use 1 tank per motor with AN tee. They have been sitting in my basement for only 10 years. Cheap, make me an offer. If you cannot see pics give me your em address to send pics.
Thanks Gary C-703-477-9071
