Crank Case Venting >
Crank Case Venting
Crank Case Venting
Old 03-24-2005 | 09:32 PM
Hot Boat's Avatar
Team Dysfunctional
Default Crank Case Venting
On a supercharge motor what is the best way to vent the block.
I currently have a trick looking air breather with at 1/2 line running up to the flame arestor. One each valve cover. I notice that there is oil in the flame arestor. I am sure that the motor is injesting oil from this configuration.
How should I vent this properly.
How is it done on a 525 SC
If it aint broke .... I can break it....
Hot Boat is offline
Old 03-24-2005 | 09:51 PM
Default Re: Crank Case Venting
I posted a question on this subject also. After looking at the parts diagram for the 525 it looks like they use a pcv valve.
Rumrunner advised against this because hot oil being injested into superchager can lead to detonation.
I'm thinking about plumbing the v/c breathers into a vented catch tank. How are others venting the block with sc engines?
PROFILE is offline
Old 03-24-2005 | 10:39 PM
robyw1's Avatar
In a perfect world you would come up with a way to have a slight negative pressure in the crankcase. having that in a supercharged engine of over 500 cu-in is pretty much impossible. Now in some drag racing applications they actually have the vent installed in the exhaust collector BUT... this won't work if there is any restriction downstream in the exhaust such as a silencer. Using a puke can will keep the oil out of your intake but at the same time you have to engineer it so that it will keep the crankcase pressure at ZERO. Failure to do this WILL result in oil showing up in your bilge coming from either the front/rear seal. Can we do this with an electric pump? Possibly, and perhaps it is worth looking into. If we can develop a way to maintain a slight vacuum in the crankcase at say 6000 RPM at full boost at the same time preventing oil from being ingested through the intake, I can tell you right now that there will be a significant HP increase.
Roby
robyw1 is offline
Old 03-25-2005 | 03:34 AM
Here is my 525SC. Set up just as you described yours. No PCV's at the valve covers on mine. I get a little oil on the flame arrestor and on the carb, but its minmal. I only use a quart every 20+/- hrs.
Griff is offline
betitbig
06-04-2006 05:22 PM
JERSEY DEVIL
Prop Talk
13
03-10-2006 10:46 AM
tomcei
5
10-01-2005 10:31 AM
seahawk
13
01-11-2003 09:41 PM
