Steering
Pirate of the Chesapeake
Steering
Maybe you guys can help me again!My fountain with factory external steering two rams.What would I have to do to be able to get rid of my power steering pump.And can it even be done with out replacing the rams,and changing everything. Thanks JOHN
It's not a problem at all. Email or phone if you like and I can spec out the right helm pump for your application. Like Darrell says though, why?
[email protected]
604 315 0570
[email protected]
604 315 0570
steering
Well I really didn't know that pump was necessary,Never had a boat with the steering pump,just had a helm and cylinders I need to run the pump low on the fuel pump side and can't find any brackets,Would a small GM style remote fill pump work?????I have cam drive water pumps and the steering belt is a issue. Thanks JOHN
steering
If I keep the pump could I run a smaller pulley on the crank to get my clearance I need. What would that do to the operation of the set up. Thanks JOHN
The remote pump will work fine, and using a smaller pulley on the crank for clearance is fine also. It will slow the pump down and flow a little less volume but probably would only really be noticeable at idle and wont cause any issues when cruising.. Either one of those is probably a better solution then swapping to a manual system.
you can install an electric hydraulic unit . they are made by latham for outboards, but i would call latham first. you can also use the pump asked about or you can buy a kpm pump which is very small and universally mounted.
