How to change antenna battery on a Livorsi GPS speedo?
#31
Ok I tried to change my battery and I'm not sure but I think I pulled a wire out. I have 3 wires hooked into to back of this thing but I have 2 black wires in there that are not hooked up. The whole thing strange because the plug is 3 wires and I have 3 going on through but the colors don't match. Has anyone seen this?
red (12v+)
white (signal)
black (GND)
You can probly take a multimeter and do a continuity check to match up the wires on the inside.
As stated above, if you can rig it to your GPS, that's the way to go.
#33
I think that I have a different guage than every one. the back of my guage does not have the seperate terminals. There is a big plug that has six wires and there is another smaller plug that is from the antena that has three wires (black, red, and orange).
#34
That's just like mine but on the puck end of that same wire the black wire dead ends and there is a green wire attached. That same green wire dead ends back at the gauge or plug end. Like I said it's weird. I need to look in my manual for my Northstar M84 to see if I can just use that for an antenna.
#35
The big plug goes to your recall switch. The wire coming from the small plug is the one you want to connect to the GPS.
You only need the signal wire, you don't need to connect the + and - wires.
#36
Ok. the wire you are referring to is the orange one. Where do I connect it to?
#37
Like Keith said above, make sure you go into the setup on your GPS and enable NMEA out, it's not turned on by default.
#38
I don't have a manual for the unit. How do I go into the setup and how do I enable NMEA?
#40
This is not a digital guage. I don't see how I can go to a menu. Here is how it looks from the front.
