Help...stuck BBC balancer
The puller doesn't have a bearing, just a cap. The cap cracked & fell out after I hit the bolt a couple times last night.
I'm trying Ray's method now. I'll clean out the coke & put in liquid wrench tonight.
I checked for a washer a couple times thinking that had to be it?
Make sure you are pulling on the hub and not the ring.
What has worked for me 100% of the time is to turn the center screw 1/2 a turn and then whack it with a brass hammer a few times, then repeat.
Make sure you are using a harmonic balancer remover (with a pivoting tip) and not a steering wheel remover (They might look the same, but the balancer puller is heavier duty and can provide 1000% more pull without ever breaking).
Good Luck!
Good Luck!
Good Luck!
Good Luck!
Success! Ending up letting the penetrating oil soak for two days. Got another puller similar to the one in the above picture for 17.00 bucks. Tightened it down & hit w/ a small mallet a couple times then tightened it down again & repeated. Never did get a load pop where it slid right off. Instead it would be a mild pop & would need to retighten the puller & tap w/ the mallet again. This was repeated 3 times with the mild pop & was surprisingly difficult to remove.
Thanks for the help.
