Running engine with power steering pump >
Old 01-11-2010, 06:17 PM
Default Running engine with power steering pump
I have a new engine and would like to test run it before putting in the boat. I need to run the pump but don't have any cylinders to connect it to. Has anyone run the pressure to the return side with a valve. any suggestions
alecsammy is offline
Old 01-11-2010, 06:52 PM
RIPSTA Racing Team
fireboatpilot's Avatar
Why not just take off the belt and not turn the pump?
fireboatpilot is offline
Old 01-12-2010, 01:52 AM
Received 1,821 Likes on 907 Posts
Exactly what I was thinking if he has V belts. If its a serpentine belt and has a recirc pump, then you pretty much have to run the belt.
Griff is offline
