Rear Motor Mount Setup
ok guys. Bought waterbums ear setup, and dropped a motor in to see how its gonna line up. Everything went perfect, except the motor needs to go back 1/2" for the rear bolts that go thru the ears and inner transom. With the front plate bolted to the L brackets, im 1/2" too far forward...damn
Now do i move the motors back to where they need to be, and re-drill the holes in the stringers, or new holes in the Aluminum angle iron to give me that 1/2"...
Could you just use a 1/2 pc of alum for a shim between the motor plate and the L stringer motor mount? Maybe drill one hole, thru bolt and then mark spacer with a transfer punch. Drill all holes in the spacer slighter larger than the mount bolts for a easy install.
Mr fixxall;
Can you elaborate on this? We are going throught it currently on a new rig job -- what does installing longer dowell pins do?
What am i missing in your description?
Are there different starters available for this application?
Thanks, Dave
Thanks, Dave
Not sure what you are rigging, but I have the mounts for the ssm setup that bolt to the transmission, then inner transom plate. I went with rear raceplates, only because that's how mine was rigged. I actually like the ear setup better. If you need the ears, ill give ya a good deal!
1 Post
Fixx
http://www.jegs.com/i/JEGS-Performan...22006/10002/-1
as for starters their are 2 different lengths to the nose of the starter,depends on how deep the starter ring is..
Offshoreonly Advertiser
Not trying to start a fight here but I have never heard of a longer nose for a top mount starter. I have always thought those come in one flavor. And if using one the ring gear is always on the rear of the flywheel. Block mounted starter uses ring gear on the front and does not care about the flywheel housing.
Also, do not forget about the engagement of the transmission to the drive plate. Most of the flat style plates barely grab as it is. The dished plates are better in that regard.
Yes, kudos on the long dowels. They are often overlooked.
Some of the standard flywheel housings don't really have enough meat on them to machine. We have taken meat off both the front and back sides (both starter & trans) to get that 1/4".
The front/rear mounts are a really good idea if the boat is going to be run hard. I personally dont like to see the engine supported by the transmission. Have seen more than a handful of cracked flywheel housings. Also the transom deflects more than you would believe. Put a Go-Pro back there and run out to one of the cribs (you Chicago guys know what those are) one day this fall when the wind is out of the NE and take a look.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
rear plates
you guys are a wealth of info !
i'm picking up parts now to upgrade a scarab s type.
i have a chance to pick up front and rear plates
it's a TRS 72c set up, and i'm wondering about losing that 1/4 inch between the trans and coupler,
what else am i missing here
any advice is appreciated
thanks
thanks
