Water Pressure Gauge Hose, what to use?
I am in the process of installing new engines and was told to put the hose up higher instead of the block as well. I am going to drill and tap the end cap of my oil cooler on the back of my 500efis , Should this be a problem?
I have used the 1/8 inch tube for 5 years with no problems. Mounted it in the top of the manifold where the plug is next to the thermostat housing. No problems with plugging. Drains in block are pluged every fall when I winterize though.
Its easy to drill and tap a hole in the rear of the intake manifold where the manifold seals off the cooling passages in the heads.
Lots of room for the fitting and never a clogging issue.
Also, being there its a pretty good indicater of any steam pocket issues as steam and air are compressable and the pressure will generally show as erratic when cruising along if there is an issue.
The water goes to the oil cooler before it gets to the engine. Some of the water going in will get bled off into the exhaust via the Tstat housing before ever entering the actual engine. It also won't tell you if the engine is building water pressure and letting water out fast enough.
Putting in the cooler is better than nothing, but putting it in the intake manifold is better. The engine is what you are trying to protect. If you are installing it so you know there is water flowing, then it work fine.
