Water Pressure Gauge Hose, what to use? >
Old 05-18-2010 | 10:47 AM
Default Water Pressure Gauge Hose, what to use?
I am installing water pressure gauges and the kit comes with about 12' of the cheap plastic 1/8 inch hose. It also has compression fittings. What is everyone else doing.
1BIGJIM is offline
Old 05-18-2010 | 11:58 AM
Tibbstoy2's Avatar
I personally used the plastic hose that comes with it and ran it inside of a Pex tube (a few bucks at Home Depot) down the side of the boat to protect it. On each end of the pex, I put it inside of convuluted tubing routing it to the engine. You can protect it pretty well that way.
I know some prefer to use copper tubing, but it seems that it would kink easily whereas the plastic stuff would typically bounce back.
Tibbstoy2 is offline
Old 05-18-2010 | 12:06 PM
Airpacker's Avatar
The white nylon tubing is ideal for the use. It does not expand under the pressure, rust, corrode or rot out. Use it and if you need more, just go to the local auto parts place and get air shock line. Same stuff.
Try to take the pressure reading high on the motor. Using the block drain holes usually plugs the line with rust after a period of time.
Airpacker is offline
Old 05-18-2010 | 12:25 PM
offthefront's Avatar
Correct .....
offthefront is offline
Old 05-18-2010 | 02:06 PM
seltzer's Avatar
Mine come off the block and clog all the time. 3/16 o.d. plastic hose.
seltzer is offline
Old 05-18-2010 | 02:09 PM
I have always just used the 1/8 hard plastic tubing. No problem with it other than it can plug up pretty easy using the block drains. I actaully drilled out my lower fitting so the tube go into the engine about an inch and that helped a lot. I have quite a bit of tubing if you need some more. I replaced mine once and had to buy a 100' roll when I got it locally.
Griff is offline
Old 05-18-2010 | 02:46 PM
Thanks guys. Yes I planned on running out top of the intake manifold. Griff, if I can't find any close to home I might be sending you a PM
1BIGJIM is offline
Old 05-18-2010 | 02:58 PM
Strip Poker 388's Avatar
Rob
Mine has the blue #4 areoquipe hose,It was in the drain holes and still cloged up with rust/dirt etc, I put it in the water crossover, didnt see much water pressure reading diff.
rob
Strip Poker 388 is offline
Old 05-18-2010 | 03:16 PM
rob
+ 1
formula 382 sr-1 is offline
Old 05-18-2010 | 03:54 PM
I will have to check that, I don't remember seeing a place to mount one.
1BIGJIM is offline
