4 cylinders on one bank fowling out
#31
my whole point is $$$ I know how to do EFI...right at this time I choose not to for cost reasons alone..but thats just me....things are tight and if $$ were no object I would run a aftermarket EFI setup in a second....but the way things are far more cost effective for me to run carbs...but to each their own...
#32
Jason,
Didn't you have programming issues with your Crockett engine upgrades?
If I am remembering things correctly you had a hell of a time getting
the engines to run properly. Why would you jump on Steve for merely
pointing out the obvious? I hope it is something simple that does not
require any reprogramming, but as pointed out, it may be.
#33
Jason,
There is no way I would take a disfunctional EFI system from an engine and repalce it with a carb knowing what I know now about correctly fixing EFI. The advantages are just too great compared to a carb.
#34
#36
I put a whipple side mount on my 99 454 mag and cant get it to run right... all four plugs on the drivers side of the engine are fuel fowled while the port side is burning perfect. Has anyone come across this before... cap and rotor? whole distributor? coil? Please help.. thanks.. Winkman!!
