Wrenches are a flying!! Water in Oil! Help!!
#83
I have been following your posts. Stay with it, you'll make it. I am heading to Havasau on Wed. morning. Hope to see you there or if you need anything I'm right down the road in Newcastle. Good luck. Doug
#84
#85
Tried to respond to your PM but OSO stated that you were not accepting PM's. I'm heading out Wed. morning really early, 4 a.m. and will be caravaning with a 35 Formula. Staying at the Hampton Inn and I always rent a 25X100 storage unit at the Islander. I have a spare set of heads ready to go, if you need them. Call me at 916 539-2540 if you need anything and let's get together at the lake. Doug
#87
Shoot..all we have over here is 91 these days...Running 8:1 and @ 8.5 lbs boost with a Chiller. I have another pulley I want to run..but it's only good for about another 1bs or so. Safe? Or safer just to bump my timing up a bit.
#88
I was gonna run my wet non muffler OTT Tips at Havasu vs my dry OTT muffler tips..Do you think they will be checking for noise at Havasu??
#89
I have Stelling headers and have never had a problem on the Desert Storm week. We usually idle on one motor as often as possible. I have clamp on's but don't run them. I was told that up river it may be a problem but so far I have not been bothered. The marina next to the Natical will not allow you to buy gas. I did experience that a few years ago. I pull my boat every nite so we fuel on the trailer. Doug
#90
Looks like we are gonna make it guys with 2 days to go. Thanks for all your help!!
http://youtu.be/w_C79Ko0OHc?hd=1
