what are these tank fitting?? want to add return line!
My guess would have been for a gen set...as far as a return line I have seen some fittings you can add to the fuel fill line....check it out:
http://www.cpperformance.com/p-16582...k-adapter.aspx
-Wally
-Wally
Brought her home Sunday!! But had to fly to ATL for he week!
Not sure what HP you have. If you upgraded the motors/pumps but I had to drill my Pick up hole (single engine) out and tap, might of did my return too. I did it like 8 years ago and forgot if I did return hole. I did it due to recomendations of the fuel pump maker and bigger engine. Also made a bigger pick up tube. FYI should be a check valve in that elbow which can restrict flow.
The fitting that screwed into the elbow had the valve on my 25 ol, but I will check.. thanks
