port tab wont go down.. >
Old 05-08-2013, 07:20 AM
Default port tab wont go down..
Port side tab wont go down. I have power back to terminal when I jhit the switch but it just clicks. Goes up fine though. Solenoid? Pump motor?
Drock78 is offline
Old 05-08-2013, 09:25 AM
Yep sounds to me like a bad solenoid, you can reverse the motor leads on the solenoid and you should then be able to put the tab down (using the up switch) making sure the motor is still operational
mickeymcclgn is offline
Old 05-13-2013, 03:38 PM
OK..I switched the blue wire with the green wire at the solenoid's and same thing happens...it will go up but only clicks when trying togk down. Bad motor? Flat spot in the motor?
Drock78 is offline
Old 05-13-2013, 03:43 PM
If you flip flopped the blue/ green wires and it works when you hit the switch UP position, the tab should be going down now. You have a bad solenoid
mr3dman is offline
Old 05-13-2013, 03:46 PM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
bad ground
bad connection at the switch
somewhere it is not getting the full 12v for the down side of the solenoid.
I had the same problem when my boat sits over the winter.I doubt the motor just went bad.
Rookie is online now
Old 05-13-2013, 03:58 PM
Tabs are just for looks. Those are the second best riding boats out there!
POWERPLAY J is offline
Old 05-13-2013, 04:47 PM
I'll have to check a few more things connections.
Drock78 is offline
Old 05-13-2013, 04:51 PM
c_deezy's Avatar
Which ones did you flip-flop? The ones from the motor, the ones from the switch or both?
c_deezy is offline
Old 05-13-2013, 04:53 PM
Did you save the reciept? Return the boat or exchange it for a new 33.
Old 05-13-2013, 06:10 PM
I flipped the ones from the switch to the solenoids.
Drock78 is offline
