600 sci, how many hours do you have on yours? Rebuild cost?
Good read! I have a 600 in my boat and actually blew a lower up with the motor still stock...I have since done the whipple upgrade.
I also have a friend with 600's in a Flame with the stg 2 upgrades running XR drives and has had no issues for 180 hours....
Update at 403 hours.... no problems runs perfect. I just ran it last weekend 94 mph without pushing it. No oil consumption, no noise. BUT.... I decided based to do a head rebuild over the winter. I know that at a minimum I need valve springs but since I want to be preventative I am rebuilding the heads entirely. I thought about changing the cam but decided against it. The boat is plenty fast and runs strong. I don't need to manage more torque through the drive. In summary I have had a whipple stage 2 running this motor for over 300 hours with no problems. I would say the max rpm that I ran is 5800... 5900. I am trying to get 7 more years out of the motor without a complete rebuild. That would put me at 750 to 800 hours. What do you guys think? Am I wasting money ? Or being wise?
We are refreshing our NA 500 ci motors this winter with 90-100 hrs. We have a lot of hours at 6000-6500 RPM. I think you are making a good decision to freshen the motors now before something in the valve train fails. If you have the engine out, you might consider dropping the oil plan to just take a look at one rod bearings to confirm all is good.
I
Have you ever had an IAC ( idle air control valve) go bad? I have heard of them going out but I haven't had one go bad yet, been thinking about carrying spare.
Airking
http://www.offshoreonly.com/forums/g...-no-boost.html
Do yourself a favor and change it as part of maintenance or go thru this and it shorts out PCM aka ECU like it did mine. Keep the old one in boat for a spare to get you home. They are not very expensive you can get at rockauto.com $39.79 or local parts house for cheap the delco part # is AC423.
To add more IAC info:
The IAC valve is listed also for :
FORD WINDSTAR (2001 - 2003)
LINCOLN LS (2002 - 2003)
MERCRUISER All Models (1996 - 2007)
Part#'s from several manufacures:
Mercruiser / Quicksilver #1F2Z9F715AA, #862998
MOTORCRAFT CX1766
Standard Motor Products #AC423
Delphi #CV10103
ACDelco#217-3217
BWD #50558
MOTORCRAFT CX1766
Delphi #CV10103
ACDelco#217-3217
BWD #50558
The BWD 50558 does not work correctly on the Mercruiser apps and FWIW it is made in Mexico, I will test this again to verify on another app to confirm 100 %. This Ford style IAC thru Merc is used on a lot of their apps across the board..
Do NOT punch holes into your oil filters to help drain them. - where do you think that metal of the hole you punched it goes ? You are breaking small metal fragments to make a hole - it drains back down into the oil system with the oil that is draining from the oil filter.
A little story OEM new boat with Mercruiser years ago - Not mine but story was new boat in for the after engine breakin 20 hour service - motor oil & filter change - tech punches hole in the oil filter to drain to prevent mess while changing. Tech completes service - boat owner takes boat out 6 hours of engine run time afterwards - engine failure - Merc warranty - sorry warranty is void - why - because we found metal oil filter pieces in the oil system. How did that happen - Who punched the oil filter to help drain it before the change ? - end of story.
Good luck with that - makes sense now why not to punch a hole in your oil filter.
Unscrew it slightly and gravity will help drain it beforehand . Tip for everyone.
Um, not being a smart ass BUP. But how would the metal, if any, from pumching a hole in the filter get past the paper filter eliment? Thats what it dose, it stops stuff from getting into the engine???????
