HELP with Fragola hose and fittings
Absolutely positive the best tool I have bought in a long time . Makes putting together AN fittings a breeze. Worth every cent , I have a ton of an fittings.
http://www.koultools.com/InstructionsAN.html
https://www.youtube.com/watch?v=tTv6d3JfMmY
They make a Push Lock tool too.
Found the problem - called Dave Wesseldyke today to ask what I was doing wrong. Turns out I have the wrong hose. Mine has SS wire under the nylon outer weave.
Koul Tools press is by far one of the best tools that I have ever purchased. It's not cheap at $250, but worth every penny. You can not only lock it in a vice, but you can also take it in the boat with you to make hoses that aren't easily removed.
http://www.koultools.com/EZ-ONHosePress.html
I would caution using random lube when installing fittings, I had a few fly off off this summer. I can't even describe the mess it made. Use only what the manufacturer says would be my advice. And that tool would be a good investment.
+1 the twist helps and I use Amsoil Dominator racing oil, slipperiest oil I have tried.
