oil leak Blues >
oil leak Blues
oil leak Blues
Old 02-16-2016, 06:12 AM
Originally Posted by horsepower1
We use and sell the.
theres no sales pitches allowed in tech.give answers .
sutphen 30 is offline
Old 02-16-2016, 06:17 AM
Originally Posted by Black Baja
I've done this many times. Before they cam out with the right stuff I would use either the Ford gray silicone that they use on all there Diesel engines (usually need atleast 18" bar to get the pan off and that's still questionable)
I still like the ford stuff better,just seems a bit stronger than the right stuff.
when you go to reseal the pans,make sure those corns of the pan aren't cracked and the pockets made by the cover and rear cap are really clean.goop and go,don't over torque.I like to let the sealant set up for an hour then torque it down.
Old 02-16-2016, 06:40 AM
It's definitely not a normal silicone. I can't tell you how many times I've had it out with that sealant trying to get a pan off. One instance I had to put my 5' pry bar on it and flexed the hell out of the bar.
Black Baja is offline
Old 02-16-2016, 06:43 AM
you want scary,how about when its on an aluminum diesel intake,,thought for sure the manifold was gonna crack.seems the GM gray diesel silicone is the same stuff but in a smaller tube for more money,,thats why I use the ford stuff.
Old 02-16-2016, 07:40 AM
funny thing on this, I had a issue with the same gasket, talked to tech at felpro, told me that they do not make that gasket, buy strait from GM, if its leaking there make sure no one hacked up the cover, you have to put cover on 1st, use RTV. also make sure you do not have a block plug or cam plug leaking at rear, these things seal well.
ezstriper is offline
Old 02-16-2016, 09:29 PM
articfriends's Avatar
Ive used the gray ones on gen 6 blocks twice in past year, tiny bit of great stuff on corners with no leaks. I assembled 2 other motors (mk4 bbc and a pontiac) with felpro blue one piece, the pontiac leaked everwhere, the bbc i could slide a .015 feeler gauge past gasket into pan so i tore it off before ever running it and just used great stuff on its own, no leaks
articfriends is offline
Old 02-17-2016, 01:50 PM
14 apache's Avatar
Originally Posted by ICDEDPPL
F*&# ! that makes sense. I have canton pans and I`ve been batlling leaks since day one, I`ve spent some hours upside down in the bilge, looking for leaks applying the Right stuff on the outside of the pans like an A$$hole.
So no gaskets and you have no oil leaks?
Takes a little getting use to doing the front and the rear of the pan. Have to fill the gap. Try to make it tall not to wide and put a wipe on the pan surface there. I have never had a leak.
14 apache is offline
Old 02-17-2016, 02:15 PM
Geronimo36
Panther's Avatar
Originally Posted by mike tkach
i use the fel pro gasket all the time BUT i apply a bead of the right stuff externally on the timing chain cover&front of pan.i call this the safety seal,lol.i have also used the grey ones without problems.
I do the same thing. Haven't had a problem yet...
But I bet now that I said it I'm going to have a problem...
Panther is offline
Old 02-19-2016, 04:03 AM
Anytime I use the blue Fel Pro pan gasket, I cut the front part out where the timing chain cover mates, and build up with Right Stuff. I also apply a bead on the rear and in the corners. The blue fel pro will squeeze out in the front and leak like all heck.I have had no problems at all after doing this way. Some pans are worse then others with that gasket.
Bawana is offline
Old 02-19-2016, 04:07 AM
Its the same concept as doing intake gaskets. You run beads of right stuff in the front and back, and throw away the rubber or cork "china wall" gaskets.
Bawana is offline
