Lightning or GiL >
Lightning or GiL
Lightning or GiL
Old 09-14-2016, 11:16 AM
  #41
Originally Posted by G-NOTE
Hey Craney, I tried to buy your buddy (kmusto) IMCO exhaust but he didn't want to do paypal. He wanted me to mail him a check and when it cleared he was going to ship them...
Ive made several purchases on here in that manner, never a problem.
buck35 is offline
Old 09-14-2016, 11:36 AM
  #42
vintage chromoly's Avatar
Why not a postal money order?
vintage chromoly is offline
Old 09-14-2016, 04:19 PM
  #43
Received 1,493 Likes on 807 Posts
Anyone heard of Kodak manifolds?
Kodiak is what they are. Never used them however would be a step up from stock and do have individual runners but not what you'd want if you have much of a cam at least with those stock risers. Also if your decking your heads make sure you check piston to valve clearance with that lift of cam especially if you advance it.
Check on available risers on those kodiaks but personally I'd stay away from them.
getrdunn is offline
Old 09-14-2016, 04:51 PM
  #44
Craney's Avatar
What is the problem with sending a check?
Craney is offline
Old 09-14-2016, 05:34 PM
  #45
I'd be more worried about valve event timing, and radial clearance with a big intake valve , as far as the piston to valve clearance goes. The valve is at max lift when the piston is down in the bore quite a ways.
MILD THUNDER is offline
Old 09-14-2016, 06:02 PM
  #46
With low lift marine cams you don't have piston to valve issues at max lift its at .005-.010. And isn't really an issue until you get into larger valves 2.3&up the valve hits on the corner of the pocket. Even this doesn't happen much until you step up to a 24* head.
Black Baja is offline
Old 09-14-2016, 07:19 PM
  #47
I had an intake 2.30 clearance problem with valako's prototype dart heads milled to get 9.6:1 comp in a 454 mag with stock Pistons. Cam was 502/465 hp advanced 4 deg.
A heads up to OP to check regardless as I'm not sure what he is or isn't doing with his build. Just simply stating a fact. That cam was only 571 lift if I recall.
getrdunn is offline
Old 09-14-2016, 07:50 PM
  #48
Exactly it's not max lift that gets you on a BBC until you get over .850
Old 09-14-2016, 08:10 PM
  #49
No offense guys but I'm not mailing anyone a check and waiting on them to send me something back. PayPal is completely safe for both parties and used on almost every trading site around. I don't even have a check book anyway...lol
G-NOTE is offline
Old 09-14-2016, 08:27 PM
  #50
I ran a Marine Kinetics cam with 114 LSA and if I remember right around 237/243 and .645/.610 with standard Stainless Marine risers and never had an issue with reversion. Not all manifolds are equal. Gils are more prone for reversion due to their design than for example, Stainless Marine. Due to this you would need a longer riser with the Gil. Others will chime in, but IMO duration is far more important when it comes to reversion than the lift of the cam. What you posted is by no means a wild lift number.
endeavour32 is offline
