Lifter madness >
Lifter madness
Lifter madness
Old 03-23-2017, 06:51 PM
  #31
adk61's Avatar
Crane 13532-16
adk61 is offline
Old 03-23-2017, 07:52 PM
  #32
Morel blow donkey balls...go johnsons
1MOSES1 is offline
Old 03-23-2017, 07:54 PM
  #33
adk61's Avatar
I keep saying it... I run lots of them in the field without issue thus far
adk61 is offline
Old 03-23-2017, 09:56 PM
  #34
Originally Posted by phragle
So I am looking at
Crane 13532-16
Crane 26535-16
and Comp 854-16
anybody ever use any of these??
13532-16 is the crane that was recommended to me also by a very good builder.
Crude Intentions is offline
Old 03-23-2017, 10:19 PM
  #35
I can only speak from my own experience. Ive seen morel lifters in 800,900,1000, and 1200hp forced induction engines, handle 550 lbs of open pressure, 6500-7000rpm, without a single hiccup many times on the dyno, and quite a few applications running 6000rpm for sustained periods of time. Icdeppls and mine probably have at least 150 hours on them by now. 150 hours might not be 300 hours, but we also arent running stock blue merc motors making 500hp , and only turning 5200 once in a blue moon.
Offshorexcursion is running their .903 diameter hydraulics on 55mm cores, also with well over 500lbs open, in his dry sump 572's and no issues.
Not sure id wanna try taking a stock gm lifter to 7000 on a 1200hp whipple engine on a dyno pull, let alone on the water. Considering some of the top engine builders are still using them, lunati , howards, erson, bullet, cam motion, herbert cams, many professional race teams, drag race, circle track, marine, etc also still using them, i hardly think they are "junk" .
MILD THUNDER is offline
Old 03-23-2017, 11:42 PM
  #36
Phragle doesn't want the tech sections help anyways....
He originally started this thread in general boating discussion for the real experts advice
offshorexcursion is offline
Old 03-24-2017, 01:45 AM
  #37
Click bait. I figured there'd be a pissin match by now. Rob, I'm much disappoint. Lol
ham_r_down01 is offline
Old 03-24-2017, 03:16 PM
  #38
Aren't the cross bars usually in the lifter valley on extended tabs?
Baja Rooster is offline
Old 03-24-2017, 03:30 PM
  #39
That is the gm dogbone lifters. Stock on gen 6. The spider plate holds the dogbones in place
Old 03-24-2017, 05:41 PM
  #40
Received 1,494 Likes on 808 Posts
What kind of intake gaskets are those? They look like they'd seal well.
getrdunn is offline
