Ok, so how fast will this old pig run? 24-7 pantera. >
Old 04-01-2017, 12:51 PM
Thats sweet looking ride there , vc!
buck35 is offline
Old 04-01-2017, 01:02 PM
Originally Posted by vintage chromoly
Prop depth correction:
"X" dimension-17.25"
Prop shaft depth- 4.75"
Perfect, Get your hands on a 27 & 29 mirage Plus. Don't even bother with the B1's
class6 is offline
Old 04-01-2017, 01:08 PM
scarabman's Avatar
You are pretty much where mine was. The biggest issue I had with a Bravo prop, was when getting into the throttle, too much bite/blade area on the prop would make the boat want to lay on its side. Once you hit a steady speed, you could counteract it with a jerk of the wheel, but I didnt like it all. Tried left hand props as a counter measure, and they helped, but didnt cure. The one 4 blade i did like on the boat, when I wasnt looking for top end, was a Hydromotive. It made the boat less sensitive to trim and eliminated some porpoise without manhandling it too much.
scarabman is offline
Just to save you money and Time. Don't bother going shorter as a Imco SC, the lower is longer and gets too close to the transom. the only way they work is on a Box. Minimum a ITS box. Just Prop that Baby right and you'll be happy. good luck with it. it looks Great!
class6 is offline
Old 04-01-2017, 01:20 PM
Porpoise comes from a prop without enough bite to keep the drive moving forward which lets the Bow keep falling back into the water. B1's also continue to climb out of the water and have a decent pull sideways. A Pantera is only 6' wide at the Transom in the water, it will need some Port Tab under 45MPH. After that Lift them up.
class6 is offline
Old 04-01-2017, 02:19 PM
A 24 with a delta pad? Did you add it? or a former owner.
Pismo10 is offline
Old 04-01-2017, 02:40 PM
vintage chromoly's Avatar
Original to the boat. I know the original owner who picked it up from Pepe and it's never been touched until I got the boat.
vintage chromoly is offline
Old 04-01-2017, 03:56 PM
So it's like a Fountain? Pad bottom? Don't tell Full Force, he won't let you take it on lake Erie
MILD THUNDER is offline
Old 04-01-2017, 04:03 PM
Panteras havIng those is news to me
hogie roll is offline
Old 04-01-2017, 04:08 PM
You can see the pad in this photo:
