Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-08-2002, 12:36 PM   #21
JimV's Avatar
27' Fountain No Step No blower No Bull
Cobra Marty
I am running the stellings box now. What other changes are there?
JimV is offline   Reply With Quote
Old 01-09-2003, 10:20 PM   #22
KAAMA's Avatar
A boat?....What boat??? How about a galvanized warsh tub wit a tornady strapped own da rear!
Sounds like it is best to run the Pro Charger with a little more compression for good cruising range then right?
Thank God for the U.S. Marines!
Hey, I'm still learning! ;)
KAAMA is offline   Reply With Quote
Sponsored Links
Old 01-10-2003, 10:13 AM   #23
blown1500
Hello, Guys,
The posts I am reading here are very correct, especially on the centrifugal blowers. Consider also that the Whipple makes much less heat than a roots-in fact, about the same as a centrifugal. The roots makes a lot of heat. The big thing about the Whipple is the low end power. If your outdrive can stand it, two boats that are identical in every way except the blower, one Whipple, one centrifugal, and both bang the throtle at about 3,000rpm, the Whipple will destroy the centrifugal. Timing curves are very different for each type of blower and would require a book (or several) to cover. Some type of boost referencing the timing curve is always best.
Old 01-10-2003, 11:01 AM   #24
Turbojack's Avatar
2003 Eliminator 30' Daytona
Blown- I will disagree on your comparison between whipple & procharger in a race. I would say if both boats were coming from off plane (1000rpm) then the whipple will kick butt on the procharger (That is if the drive on the whipple holds together) I would have to say from a 3000rpm stomp the procharger is going to be right there with the whipple. I know that when the throttle is wide open the intake manifold presure for the whipple will be at or close to the max boost at high RPM's & the procharger boost increases as the RPM's increase thus the whipple will have more low end torque. In reality when I stomp it at 3g the motor raps to 4500 right away & then keeps on climbing. At 4500 rpms my boost will be close to max.
Turbojack is offline   Reply With Quote
Old 01-10-2003, 11:03 AM   #25
KAAMA's Avatar
Thanks 1500
Old 01-10-2003, 01:22 PM   #26
blown1500
Turbojack,
I can only speak from experience on the water, in the land vehicle, or on the dyno. The closer you get to max rpm and boost, the closer the two get, but the lower you go the more the Whipple wins!!!!!
Old 03-07-2004, 11:07 AM   #27
1975 X-18 Donzi, Arneson
GEOO's Avatar
Boating, scuba, fishing
Tom Cat, Turbo Jack,
Good guess,,
I lowered the CR to 8.5 did one pull, with the old 324IC set up, lost 20hp do to the lower CR.
Then switched to a 504IC, cleaned up the piping a little, (Quickly just for dyno work), and gained 131hp @ 6400rpm's and gained 4.5 psi of boost (3.8lbs vs. 8.3lbs) with the same 5" pulley.
GEOO
GEOO is offline   Reply With Quote
Old 03-08-2004, 09:31 AM   #28
jaroot's Avatar
1997 16 Donzi Classic - 350 / Alpha SS
so what you are saying george, is that we're gonna see a trail of fire behind might mouse this summer???
jaroot is offline   Reply With Quote
Old 03-08-2004, 12:03 PM   #29
jspeeddemon's Avatar
boating
TurboJack I will back you up on that. The fuel injection having cleaned the cylinders up at lower RPM's, bringing the air fuel ratio up to a reasonable level that it no longer is puking raw fuel, I can do a full throttle roll at 65-70 with my M-4 and blow the prop completely out. That was a pretty broad statement to make, not true in every case.
jspeeddemon is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
detonation alter ego General Q & A 11 05-10-2004 09:19 AM
HP500EFI with premature detonation F1campion General Q & A 14 03-05-2003 09:36 PM
Good article on detonation Intolerant1 General Q & A 5 01-26-2003 03:08 PM
Detonation - what is it, what causes it and what stops it? tomcat General Q & A 15 10-29-2002 08:35 PM
Detonation Problems dirtlawyer General Q & A 21 06-01-2002 09:23 PM
Search Engine Optimization by vBSEO 3.2.0
